Anybody have the X-monitor?
Steering Wheel Accessory Commander
What type of fuel additive for the ULSD
JSzewczyk
I finally had time to look through the Geno's catalog and I'm debating about which products to use. I was going to go with ISSPRO dash mounted cluster of three gauges plus a fuel pressure gauge in the single pillar mount. This was my plan since I bought the truck. However, after seeing the options in the catalog i was thinking of going with the dash mounted x-monitor for the transmission temp, egt, boost and ten putting the same fuel pressure gauge in the single pillar mount. I was hoping that some you would give me the pros and cons of both ideas. Also how does the x-monitor dash mount llo compared to the other option. I have never seen it dash mounted. Which one will do you believe is a better plan for my 06 Mega cab??
I went with the X-Monitor because I didn't want to lose the grab handle. It mounts, nicely, just under the handle.
It works fine. Once in a great while, the sun shines at a certain angle & reflects on the face of the monitor. But, that's very rare.
The guage has a memory function so that you can see your highest & lowest numbers. Used that once testing a new box. Nice to have, though.
Don't know anything about the dash mount. However, I would have the most important guages mounted where you can easily read them.
If you are towing a tailer in the mountains with windy roads, you don't want to have to take your eyes too far off the road to check guages.
Joe F. (Buffalo)
Joe F. (Buffalo)
Joe, I couldn't have said it any better myself :)
