w2mp2l;
The newest X-10 stuff I have is from X-10 on the web. .
My older stuff is either from ADI, X-10 brand.
Or Radio Shack.
Its all the wall switches driving me nutz. I only use external wall plug modules for the Ram heater, xmas tree and choo-choo-trains around the xmas tree. They always work.
Most of my switch failures are mechanical. They continue to work via lcm, but the actual switch part fails.
I have a few that at times refuse to respond. I added a cap across the phases, helped some, didn't help others.
It seems the cap made the ones that are on the other phase better and others on the same phase as the radio link and macro module worse.
Some seem to turn on when ever they want. I removed the macro module, and those problems still happened. I think it's line noise.
I guess running 4 computers at all times in the house may not be helping.
I have one switch location that wont turn on, but will turn off. They say thats from not having enough resistive load on the output of the switch. But it's 80watts of bulbs... more than enough. It will turn on from the mechanical switch, but not from line carrier modulation (lcm) commands. In all honesty, I need to double check the wiring in that wall box. But at 1st it worked well. Than the switch started not responding at times. It would turn on but never off, through lcm. I replaced the switch, and now it wont turn on, but will turn off via lcm.
I had 4 switches forget their codes. . they stopped working on the address I originally set them at. I changed their addresses and they would work via lcm on the new addresses, set them back to their original address and still wouldnt work. It's not dirty contacts... emailed the X-10 folks, they had no idea, if they did , they wouldnt admit it. I'm guess the stuff may be crap.
My wife is starting to hate the x-10 stuff...
Bob
