well, to answer some questions, ..... i did use NOS, but i did because i had to before, but i don't think i need to any more. The shaft is not Billet, and i didn't think anybody made billet 2WD out put shafts. It snaped right were the splines meet the shaft. I do have slicks and lots of HP and the truck is 6,900 lbs. As for the smarty, this was really crazy. I have never, (or at least i thought) had problem with torque management, but i went to a loose converter and T/M was killing me. After 2K the power would come off with BDDL and also smarty on level 7. I like the smarty because of extra fueling. But anyways, i put the BDDL and put in extra low end with no more T/M and it had power like never before and then snap! I thougt the smarty would get rid of T/M. What i might try later is level 9 or start using my BD rad box and the Smarty at the same time. lots of questions i need to figure out. I'm not too stressed over the shaft. Its fixed, took me all of one hour, but i am planning on changing the O/D section to a 4X4 and using a billet shaft and then sticking two US gear O/D's after the trans. They are already mated together, the only thing i'm worried about is if the US gear has strong enough shafts.
