I'm trying to pin down a noise on my 92 V6 Toyota Pickup. Here's what I have. Basically my little gasser sounds like a little diesel at idle. Here's a better description...
Steady knock/tap in sych with engine RPM - most noticeable when engine is warm and at lower RPM (<1200). Listening closely with an improvised stethascope, my ear wants to locate the sound at a lifter or valve. I can't pick the sound up very well at all from the bottom end. With my scope on a cylinder head bolt or valve cover bolt or on the exhaust manifold I pick it up very well. Sounds metallic so I'm pretty sure its not an injector.
Possibilities:
lifter
exhaust leak (except that it sounds metallic to me)
piston slap
rod knock
I'm hoping its not piston slap or rod knock as I plan to do some work on the top end and I don't really want to have to pull the engine. If it were bottom end, I would think the sound would be most noticeable at higher RPM (wouldn't it?).
Ideas?
Thanks,
-john
Possibilities:
lifter
piston slap
rod knock
Ideas?
Thanks,
-john
