Anybody want to sell their 17" Steel Dually wheels?
New Bumpers and a Trip to AK
04 or 05? Advise
If you do let me know how much. I need all six (seven if you want to get rid of the spare as well). I am currently in Southern Ca. Prefer to get them without tires. Thanks, Jason.
Cattletrkr said:
now ya got 2 PM's. Mine are better. ;)
oh yeah. from mn huh. i betcha they are all rusty. :D
thats ok,,,i got 3 other pm's too interested in the wheelsand one of em is close to you so less freight $
Third-Gen wheels fit 2nd Gen dually?
I'm interested in this subject. Will the 17-inch, 3rd Generation wheels fit my 2001 dually? Are all the specs same as my stock wheels, except diameter?
The cause for questioning - I'm planning to make a swap to the inverted T-style tie rod setup. And there may be a chance of interference with the tie rod ends and the inner wheel rim at full turn. That's not a huge concern, but I'm thinking that 17-inch wheels will eliminate this problem.
But, not if they don't fit as they should... Are dimensions the same? Like offset, backspacing, and center hole diameter (to keep the hubcentric centering)? Is the hub shell for AA axles the same diameter (for the hubcentric fit) as the Dana axles?
Thanks for any help,
John
Dodge hasn't changed the specs on the hubs since '94. Rickson sell the 19. 5's as fitting 94-newer and 93-older. So yes, the 17's should be a perfect fit on an '01.
Muddy,
My truck only gets driven to church on Sundays and I wash it every week. :-laf Actually they were only on for about 8 mos or so and almost not at all in winter--maybe a week by the calendar. Soooo--- :p :p :p ;)
