Engine/Transmission (1998.5 - 2002) Anyone done the TSB to removed the crankcase breather bottle?
2nd Gen Non-Engine/Transmission Rear Pinion Seal?
2nd Gen Non-Engine/Transmission ABS motor
If you look under your truck and in back of the motor you will see a clear 1"
hose, that would be it. Had it done 3 years ago. Also added a bottle to get any drips. Much cleaner then having it up front :D :D :D
Silver Bullet Ram said:
I just had it done on mine. I see the bottle is now gone. My question is now how does it breathe and where does the oil go to now?
Gary
They replace one of the side covers behind the injection pump and some new fittings. The timing cover hole is plugged off.
Did you pay to have this done? SNOKING
ASK TqT (Torque This) about his new TSB style tappet cover / breather setup. It's layin outside in the parking lot somewhere or even across the street LOL!
I am curious toolman, how did it end up across the street? Did it blow apart?
Since day 1, it did nothing but leak... 3 gaskets to stop it from leaking, I don't know how many hours I spent under the hood. I have got the VP-44 removal, filter housing, injector lines, ECM, lift pump bracket down to about a 1/2 hour now... :)
Stick with the add on piece of hose...
