anyone else got their PDR hx-40 yet
westach fuel pressure gauge install
19.5 tires and wheels
Received my pdr 40 yesterday after a back order delay,I was told I was fifth on the list and was wandering if anybody has installed there new bomb and has any feedback. I only wished I hadn't welded my jardine exhaust at the down pipe connection as this will lengthen the installation time quite a bit. Hopefully there will be some feedback next week I have to spend to many hours at Ford KTP this weekend to attempt the install.
I put mine on two weeks ago. Lower egt's and with the 4' exhaust an awesome sound. Lag doesn't seem any worse than stock. More power-great.
Just recieved my PDR Hx-40 today and have not yet installed it. Plan to go ahaid and put it on this weeked. I'm sure I will be really excited with it. Along with the turbo I'm also going to put in the 370 injectors I ordered from Piers. How far should the #10 plate be slid forward in the pump to get the full use out of these injectors.
got mine in few weeks ago and love it. sure helped egt while towing up the big hill:D sppoolup is gtreat too. :) im tickled w/ the pdr40. cruising at 65 on level w/ tt egt is a little high though at 1000. but climbing hills the pyro needle moves very slow tween 1200 and 1300 instead of just shooting up there. boost is 36-38
Hey Tim, happy to see you back in the bombing mode :D. May I suggest a dual disc pulling clutch before spring?? Larry
Hi Larry
Thanks for the suggestion but I think I'll pass and leave my poor ole con o as the weak link ,heck I can't run with you big dogs anymore so I just have to stay on the porch and maybe get to do a little hot rodding from time to time. I'ts good to hear from you though,give me a call sometime. Tim
to thaile
Just a suggestion but maybe you should leave the plate where it is until after the other bombs that way you can compare the difference they make alone ,as a small move on the #10 plate makes quite a difference by it's self,and it's easy to adjust later.
