Engine/Transmission (1994 - 1998) Anyone ever had to replace a PCM because...
Engine/Transmission (1998.5 - 2002) BHAF & HP Lost?!
2nd Gen Non-Engine/Transmission 26 gallon tank with strange guage
Have any of you guys or any one you know ever had to replace a PCM on a 47RH equipped truck because the TPS voltage wasn't within spec and therefore the TC wouldn't lockup?
Or put another way, has anyone ever replaced a PCM to correct the issue of total failure of the TC to lockup?
Just for grins and giggles... did you attempt to install a lockup switch to see if the problem really is the pcm, or farther down the line? That would be a good place to diagnose. .
as for the pcm failing like that, I havent heard of it but I guess its possible. I just installed a relay-type mystery switch with a momentary on the other end, and man does it work niiiice...
good luck
-j
good luck
-j
Hey, thanx for the tip.
Can you suggest any threads discussing this relay-type mystery switch with a momentary on the other end???
