2nd Gen Non-Engine/Transmission Anyone ever remove passenger side airbag unit?
2nd Gen Non-Engine/Transmission Remove rear ABS?
I have a new rattle that is driving me nuts. It sounds like it is coming from inside the dash just above the passenger side airbag. The slightest little bump sets it off. I don't see any way to get to that area without removing the airbag unit - which I really don't want to do. Anyone know how to remove it or have an idea what might be rattling? Thanks.
Steve
This info is for a 1998. 5 2500:
Be sure to first pull the fuses on the system and disconnect the bag from the system. After that, treat it like a loaded gun---always have it facing away from you. (The connectors for the airbag system are colored yellow for identification. )
On a 1998. 5 2500, I remove the glove compartment box by opening and then pressing in on its sides. The airbag is secured by 4 10mm bolts--two in the front and two in the rear. They are the only substantial bolts in the immediate are. You make have to remove some miscellaneous screws in the area but is really is quite accessible.
Good luck.
Anyone know how to get the dash cover that is in front of the passenger side airbag off? I got the screws out on the lower left and right sides, but the top edge of the cover is still attached to the dash somehow. The truck is an '01. Any ideas? This rattle is driving me nuts!
Steve
