... On a quad cab length truck?
I did that on my '91 standard cab when I installed an aftermarket US Gear overdrive unit - was a BIG improvement in eliminating the common "shudder" those trucks had when moving from a dead stop - but in that case, the driveshaft was shortened anyway by about 20 inches, which made the single shaft more possible.
I wonder if it's do-able on a truck like my Quad Cab, or if there are definite hazards involved in eliminating the center support bearing assembly?
I realize one function of that center support is to maintain shaft alignment to the transmission - and another MIGHT be to provide for a pivot/length compensation point as the differential raises and lowers thru it's range of movement - so are those functions outside the ability of a one-piece driveshaft to overcome?
I sure wouldn't want to place the NV-5600 at risk...
