anyone got a 91-93 intake pipe (casting)?
New owner of an '89,Need a used service manual
REPAIR MANUAL
I'm hooking up my intercooler, and I need a 91-93 intake pipe. Mine is a casting that runs over the top of the engine; I need the one that turns down next to the injection pump.
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, K&N, cleaned up exhaust, Dynomax straight-thru, rebuilt pump, intercooler, louvered fenders, 93 aftermarket smoothe grille; 78 35'Avion. Jesus saves!
Aw come on! One of you guys is BOUND to have installed one of those Banks twin-tube intakes! I need your old stock intake!
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N air filter, cleaned-up exhaust, Dynomax straight-thru, rebuilt pump, 12cm wastegated turbo, thermostaticly controlled twin 14" electric fans, intercooler, modified 518 OD transmission, Gear vendors OD controler, R-134, louvered fenders, 93 aftermarket smoothe grille; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. Jesus saves!
I'm not sure but I don't think that the 1st Gens could use the twin ram from Banks.
90 W250, 5-speed, isspro gauges, 16 cm2, K&N, Borgeson shaft
Well, *I* have the stock casting from when I installed the Banks intercooler on my EARLY (non-intercooled) '91 - but it crosses OVER the top of the engine, not down next to the injector pump...
Early '91 250, 727 AT, 307 rear... Banks Stinger exhaust, intercooler... US Gear OD... MORE than a match for every new PS Ford encountered so far...
Congratulations Matt S for the 2000th post to the first gen site!
'93 W350 Club Cab, Bright White, 5 sp. , 132K, Factory Options: LE, 4. 10 Limited Slip, 7600 lb. rear springs, tachometer, front stabilizer bar. Mods: Banks stinger plus, Linex bedliner, 25,000 lb gooseneck ball, 10,000 lb receiver, Tekonsha brake controller, POWER WAGON injectors-WAY faster than stock!.
