Taking this one step further,
On my 02 there is a tank supply line and a tank return line in the tank cannister. "I" think there is a problem with both the supply and the hot return in the same cannister, ie the hot fuel to cool the VP just recirculates (some ~30% is burned, 70% returned to the tank cannister). BUT, that means if you return the hot fuel to the tank vent line you still have 2 possible supply lines from the tank.
TDR CStewart has a cnc replacement fitting ($30@2) that replaces the plastic fittings in the cannister top so you can do whatever you want with the 2 fittings. He has a good thread about how to rebuild the supply line with a full 3/8 tubing and replace the cheap aluminum screws in the tank cannister with stainless steel nuts and bolts so it slides correctly and does not bind up (ie incorrect tank level readings).
However, I am also going to rebuild the return line into a feed line so I will have 2 feed lines. One for the OEM lp, and one for the RASP, each independent of the other.
IF you have an intank lp, then you could do some replumbing of the return line to the tank vent line and take the return line in the tank and make it a RASP feed line. Turn on the intank lp as normal with the RASP before engine start, let it feed the VP common line. Crank the engine, RASP comes up to pressure using the second feed line and the hobbs shutsdown the intank lp (and the RASP intank lp reverse bypass on the intank lp prevents backflow back through the intank lp). IF the RASP fails, the hobbs switch turns on the intank lp and it then feeds the VP. You have to do a little more plumbing than I did initially, but I will have to replace the plastic OEM fuel cannister top fittings within a couple of years anyway. You just got to it before I did.
I could be wrong, but I think the intank lp should work with a little extra effort that will have to be done eventually anyway.
Bob Weis
