Anyone had water in the vents?
Lug nut size
Xenon Flares
I'm about to take my truck in for the first warranty repair. It's spewing water out of the vents. Anyone had this issue?
how's the weather been down where you are??? have you been using the A/C much? maybe the heater core/evaporator core box drain tube is plugged and the condensate isn't draining out... the drain is in the pass. side comes through the firewall and you can see it from over top the R/S fender if you peek in and down against the firewall. . a short black tube sticks out... maybe try sucking it out with a wet/dry vac. . that might be the cause and could save you a visit to the dealer???
Yeah, it happened to me this winter. It had been raining real hard, and when I would turn a corner, water would slosh out of the pass side floor vent. I took it in to the dealer who said that the drain vents had clogged. They cleaned out the vents and dried out the carpet. No problems since.
