anyone have a 47rh to swap for 47re
Bombing a Deutz
Baddest of the bad! (Diesel Challenge)
does anyone have a 47 rh that works or is rebuildable that they will swap for a 47re? trans has to be for 4x4. i am doing a swap from a v10 to a 1st gen 12 valve and need more gears, im using a 727 right now and need to trade the 47re for one i can use without a ecm. i am 5o miles south of chicago il. and dont want to travel too far to get it. if you are close and have one let me know. thanks
You can run the 47 RE without an ecm. I have mine in my Chevy with a full manual valve body and two switches to operate overdrive and TC lock up. I had the transmission guys at BD power set it up for me.
Malcolm
thanks for the info, i found a shift kit to turn the valve body into a manual on ebay for 118. 00 if anyone else needs one the part # is tfod-3 it is by trans go.
