Anyone have a clue what this pump is??
Speaking of electrical gremlins..I have some rearing their heads....
4" Aluminum Exhaust?
Too bad we can't see the Bosch numbers on the side of it... I tried importing the picture and enhancing it, then, enlarging to see if I could make out the info but too much distortion prevents using a part number...
It looks like it would be an application that doesn't use an aneroid system which, likely suggests an application like a genset, marine, farm use etc... .
No matter which alternate usage the Kw output will be less than the output of our applicable pump's ..... at least that's according to the spec data I have... .
bob...
Good question swank..... I honestly don't think the turbo/non-turbo is relative to the aneroid usage... . I mean, I think the application will determine whether it's a turbo'd appl. Since the diesel does not develope it's own vacuum the air's gotta come from some place ... right... ?
For example... right now, I have no AFC fueling on line in my truck. . (valet switch) and I would still need the turbo to burn the fuel... . hmmmm... what do you figure. . ??? any thoughts guy's ... :D
pb...
yeah, i guess it makes perfect sense that if it's a constant state type app, it wouldn't need the android. hmmmmmmm... ... ... ... . new places to look :cool:
Well at least we know what it is for. I noticed the timing marks are on the side that would be toward the engine block.
