Details here: TDR Privileges
A buddy of mine said there was a pdf for changing injectors. If anyone has it, can you forward it to me at -- email address removed --. Thanks in advance, Matt
what do you need to know about changing injectors and what the hell is pdf I am not very big on internet lingo sorry.
the injectors are simple to change loosen the inlet lines on the side of the head remove the valve cover and find the correct size and thread pitch bolt then take off the hold down brackets and pop them out!! put back in that order and you should be on your way to happiness and sore cheecks
Keith, Thanks for the origins of the pdf. I'm putting in used bosch rv injectors this time, but I'll keep you in mind next time. I'm sure they'll be another set after a while the way things are going. I'm sure I'll need a clutch first though .
