Anyone heard of a PTO winch?
Ground Effects Package
SPA Gauges
Wiredawg
Anyone heard of a PTO winch made for the 6-spd? There are PTOs on the transmission, but have not hear do anything to connect to 'em.
Wiredawg
2000 4X4 SLT QC 8' bed; 6 spd, 3. 54 ; BD exhaust brake and 4" exhaust syst; TST PM2; Airlift Super Duty rear air bags; RS 9000 shocks; pyro/boost gauges in 2 gauge a-pillar mount; back preasure gauge mounted under dash; KN air filter; Brown's Welding brush/grill guard, rear bumper & headache rack; nerf bars and aluminum roll top rear cover, Warn front receiver and Hadley air horns, 20K Reese hitch.
Wiredawg,I had a '64 PowerWagon with a PTO winch,it was a pain,there was a clutch and gear box right at the winch,the whole unit probably weighed 700 lbs.
If you want to go with a non-electric wench,get a hydraulic one. They are readily available,just hook up a pump to the PTO on the transmission,routing hoses is easier than driveshafts. Once you have hydraulic power you can use it to power an air compressor ,generator or they even have backhoes that mount in the bed. Good way to go.
PTO's (Power Take Off) can run winches, compressors, pumps and generators for examples. A PTO winch can be mechanical (uses a drive line) or hydraulic (uses pump and hoses). It is very hard to find mechanical PTO winches these days unless you go big.
Here are some winch/pto urls in case you get bored: http://www.ramsey.com http://www.rawson-koenig.com/ http://www.warn.com/ http://www.dpwinch.com/ http://www.milemarker.com/ http://www.superwinch.com/ http://www.ptospecialties.com/
FYI - The advantage of running the PTO off transfer case vs the transmission pto port is that you can select the speed that the accessory runs at using the gears of the manual transmission (not sure about auto's) instead of the engine RPM.
They do have pto's that run off the engine my friend had a 97 ram tow truck with the set up it worked great. If you would like more info email me and i will ask him. he said it was the best way to go i cant remeber the resoning behind it but he says its the way to go.
97 3500 4x4 ext. cab sun poppie YELLOW, Alcoa five star rims, hadly Ambassader air horns, mopar diamond plate running boards w/ tons of running lights, weather gaurd diamond plate tool box w/ running lights (60 marker lights on the truck total), HX40 turbo w/ 18. 5 mm housing, big valves, ATS exhaust manifold, big head gastket, BD 4 inch pipe from turbo to 5 inch tip, big injecters, tons of pump work, Auto Wurks custom larger intercooler, BD custom transmission w/ custom torque converter, Torque lock, Pressure lock, turbo blanket, no smoke valet switch, Mag hytech rear and transmission pan, and some other goodies all done by AUTO WURKS DIESEL. Thanks to all who have helped me build my truck, mike (THE GURU), chris, and the whole Auto Wurks crew, Piers (THE MAN) at BD, and all of my family and friends. Still not as fast as my 97 VIPER GTS (AND NEVER WILL BE).
