Optimum oil temp?
Tex, some info for you.
I went out and looked thru my Big cam 4 and Signature manuals and found this:
Big Cam 4, The thermostat will bypass the oil past the oil cooler until it reaches 230F then it opens until oil cools to 225F.
ISX/Signature, to test the t-stat, suspend it in oil and heat until oil is 240F, t-stat should be fully open.
The ISB manual did not address oil temp that I could find quickly.
"94" B series manual said, "typical oil temp. is 230F"
It looks to me that they dont want too cold of oil due to possibility of varnish and sludge, the same reason they want minumum coolant temp to run 160F. In my experience oil temp usually ran 25-30F higher than coolant, when on the dyno with stock horespower. This would put the average oil temp @ 190f when coolant is at 160F min.
So, my suggestion is if you want to run an oil cooler, don't let it cool below 180-190F to prevent sludge.
I freely admit I don't know the advantage to cooler oil, it just looks like the Engineeers of these engines want fairly warm oil.
Do not mean to start another oil argument, its just info I found to help you guys make decisions.
A Johnson
