Anyone know if a dual voltage Alternator is available?
1st oil change observations
2001 Cummins Ram for Sale......
I am trying to find out if anyone makes a 12/24 VDC unit that will replace the factory setup. I have a fifth wheel that runs both 12 and 24 and would really like to be able to charge the 24 system from the truck also. Any help is greatly appreciated.
TAZ... 2001 2500 SLT+ 4X4 Auto ETC Cummins, LSD 3. 54,Quad Cab, Long Bed, Agate Leather, White/Driftwood Exterior, Sliding rear window, Camper Special Group, Towing Group, Cab clearance lights,SPA-Technique Digital Dual Gauges (Pyro/Boost, Trans pressure/temp) Aux. Backup lamps. BNM 5th Wheel Hitch, Additional Body Molding on Bed. Line-X bed-liner. DTT's TC & VB, Pac Brake, Power Edge, Edge EZ, Grover Air Horns
2000 32' Aljo Triple Slide 5th Wheel.
http://www.ramtaz.com
Add on's to come: any other Ram Runner required modifications...
Mike, Don't know if this will help, But I installed a Mobiweld Welder on my jeep, and I believe that they make dual voltage Alternators. They sell both welding systems and replacement alternators. The Cores for the alternators are Bosch. They are changed at mobiweld for step up voltage. Their website is www.mobiweld.com
01. 5 ETH/DEE QC, 2500 4X4, 3. 54 Everything but leather
if you cant find a dual voltage alt, you can get a dc-dc converter that will produce an isolated 24vdc. It's probably about the same cost of the alt.
[This message has been edited by bobk (edited 03-15-2001). ]
I have thought about the DC-DC converter and that is definatly an option. To answer the question of what is 24V, I live in my 5th wheel full time and I am a Computer Network Administrator so I have lots of computer equipment that I need decent uninteruptable power for. I have recently installed a Trace SW4024 4KW inverter (Line Tie) that is 24V imput along with a 400W wind turbine generator and getting ready to install some more solar panels. The rest of the coach is all 12VDC which I also have solar for and may put a turboine on. I live in the middle of nowhere and our power kinda sucks. Being in CA is insult to the injury. Also I am starting to do a lot more dry camping while traveling and it is sure nice to be able to go several weeks without a power plug.
