This weekend when making a long trip to Bristol TN towing the 5er I noticed some type of fluid on the right front suspension. It was dripping in the same place the a/c water normally drips. Right front pasenger side. After looking at it for a while I found the source. It is a hose that has a strange plastic fitting in one end and lays on the passenger side wheel well about the location of the stock air box. The other end goes to something mounted on the passenger side of the front axle. The fluid appeared to be gear oil?? Is this the front axle air vent? Do I need to be concerned? should I just check the front differential fluid level?
97 4X4 QC LB 3. 54 Auto w/ Suncoast TC, TFOD shift kit, Jardine 4 inch exhaust, TST #8 plate, Firestone Air bags Rancho 9000's
