HEMI®Dart
Maybe someone can figure out this problem.
The Company I work for makes Rotary Dies. Like the one below.
The problem we are having is that some (1. 5%) of the tooling will warp during the heat treat process. When it warps, most of the time it goes into the scrap barrel.
I'm not sure who makes the heat treating machines, but they are electrical. The die goes in-between centers verticaly and a copper ring a little bigger than the body of the tool is placed around it. When the heat switch is pressed the ring turns the tool red hot then it automatically lowers it into the Quenchant. Then it raises back up after 5 minutes.
These are the things that were checked, and made no difference:
1. ) Die blank cut from the middle of the bar stock v. end of bar stock.
2. ) Use 6" bar stock to make a 3" die. In other words make sure the burnt layer or outside of the bar stock is totally gone.
3. ) Quenchant Ratio, Quenchent Temp, Amps v. Die size are all right on the money.
4. ) Operator makes no difference.
5. ) Humidity and plant air temp make no difference.
