Anyone removed "edge filters" from injector lines?
I was reading the Dodge manual, and they mention "edge filters" in the six connectors thru head to injector body.
Anyone here removed those? Why spend on a new CP3 while having a built-in restriction in the injector line which prevents full rail pressure from reaching the injector?
The only downside is that if the cp3 pump sheds any metal larger than about 25 microns, it may clog the injector needle causing it to get stuck open.
