Anyone running a 325/60/20 combonation
DRB III's are Expensive
tonneau cover help
I have a 2003 2500 4X4 wondering if anyone is running a 325/60/20 combonation. I am looking at weld wheels 20x8. 5 with 5. 125 backspace and toyo A/T tires. Any info on fittment clearence, rubbing would be appreciated. Also have a 2" leveling kit installed... ... ... ... ... ... Thanks Dave
I am running the 325/60/18 Toyo Open Country combo with just the 2" leveling kit and the front tires rub a little on my Bushwacker fender flares. I am not sure that 20"s will fit?
Also, 2" of lift in the front only may not look that good. You may have to go higher. Mine with 18"s is about as low as I can stand. The truck would look best if the back was brought up 1", but I don't know of anyone that does a 1" block to lift the back only?
The 20's will fit the same as the 18's unless your backspacing/width is different. The 325/60/18 would be the same size width and heighth wise as the 325/60/20. The only difference is the diameter of the wheel. It's the backspacing and wheel width differences that would be the factor.
the 325/60/20's will be 2" taller than the 325/60/18's but the other dimension will be the same
Interesting... . I checked the tech specs on Toyo's site and not only is the 18" version 2" smaller in diameter, but it's almost 2" wider as well. Talk about misleading :confused:
I just put the Nitto Terra Grapplers on my '02. 325/60/18 with Centerline Bullets (18 x 9 wit 4 1/2" Backspacing). It looks cool but it IS a wide combination and sticks out about 2" past the fender. I don't have the leveling kit on it yet and it rubs on the outside in the front and back. I think a 5 1/2" Backspacing would be more ideal considering the wheels that came off it have closer to a 6 1/2" backspacing..... as well as the lift. It's next on my agenda; I'm considering the TRex spring and bilstein package ($350). For now I have to baby it to keep it from rubbing.
1" block
20s arent my cup of tea, but i know exactly what you mean about the leveling kit not being quite level. i looked around alot and ended up going to my local spring and suspension shop and got new u bolts and a 1" block for the rear springs, it leveled up the truck real nice and gives it that stock raked look, i wouldnt have it any other way
Just ordered my wheels and tires. The wheels are Weld Renegade "8", 20x9. 5 6. 125" BS. The tires are Nitto Grapplers 325/60/20. Very pricey, but they are the only wheels I found after much research that have close to the factory offset 6. 125". I was told that the wheels would fit with alittle trimming of front black spoiler valance approx 1/2". And minimal inner front wheel well liner trimming as well. The would stick out approx 1-11/2". I am also running a Rev-Tech 2" leveling kit. I will post photos as soon as there installed... ... ... .
