Just wondering if anyone else has sever had a problem with totally shearing off a Dana80 yoke leaving nothing but pieces on the track? My brother has now done it twice now. The truck is a 97 Reg-cab and is right in about the 500hp range and has a big set of traction, blocked suspension. The first time it happened he was actually doing a burn out. This was shortly after he installed a few extra leaves in his spring pack. I would think that pinion angle would take out the u-joints before the entire yoke???
What do you guys think? The traction bars are atatched to the lower U-bolts below the axle, maybe weld the brackets to the axle instead?
RyanB
RyanB
