Anyone using larger then HX40 turbo?
JRE tests the HX40/16cm2 wastegated
Dual Exhaust
Howdy all,
I know, a little knowledge is a dangerous thing in the hands of an amature #ad
but I am very curious. I was just browins the Holset website, and I happened to find a listing of all their different turbos and a graph showing their various turbos and what HP range Holset lists them as bein valid for.
Since I am seriously thinking I'd like to get Godzilla very familiar with the 400 HP level, I figured I would likely upgrade to an HX40 at some point. Imagine my surprise at seeing the HX40 listed as being suggested by Holset for use at 250 - 375 HP! I know there are some TDR members who make significantly more than 375 HP, but I have heard almost nothing at all of anyone using anything larger than the HX40. I remember hearing of an H2E, but I don't know what that one is. I don't remember seeing it on the Holset site.
So I'm just curious to know if any of you are using any turbos larger than the HX40, and if so, what HP are you making?? I believe someone once told me Nowel has the HX40 on the Red Rocket, and he is at 600HP!
Thanks,
Tom
Get outta the way: The Cummins is Cummin'!
Tom Golden
Godzilla: Patriot Blue 2001 2500 SLT QC 4X4 LWB ETH/DEE, Tow & Camper packages, 3. 54 Ltd. Slip, 4 wheel disc ABS, Isspro EGT/boost gauges, black SmittyBilt nerf bars, K&N RE-0880 & pre-filter, no silencer ring, TDR decal, Jack holiday antenna ball
Upcoming BOMBs: DD Stage 3 injectors, fuel line upgrade, 4" Jardine exhaust, full Psychotty air system
2001 Zinc Yellow SVT Mustang Cobra on order
NRA Life/CRPA/El Dorado #26 F. &A. M. of California
Tom,
The thing to consider about the Holset site is,the engines these other turbos fit have a lot more displacement. Which is why they suggest the horsepower levels they do. The HX-40 is from an engine with around 100 or so cu. in. larger displacment than our 5. 9's. These turbos will flow a lot more air, at the expense of low RPM power, in most cases.
Don
I believe that HVAC used an HX40 for his 600 hp run, but I am also fairly sure that he now has an H2 on his truck. I read that Marco was putting some kind of varaible vane adjustable turbo on. If you want to see the real cool set up check out: https://www.turbodieselregister.com/ubb//Forum3/HTML/002785.html
There is a picture of Sportbike's dual turbo set up.
John D. Rathert Jr.
01 2500 Forrest Green Sport SLT+ QC LWB 4x4 Auto 3. 54 rear end with all options avail. DC Nerf Bars, DC Grill Gard, DC mud flaps, Line-X bed liner, Leer 160XL Topper, Power Edge, EZ Edge, SPA Boost/EGT Gauge on pillar mount, DDT's tc/vb combo, 275 RV injectors, DD 4" Exhaust and a KN RE0880 where the air box use to be. New turbo (HX40), SS fuel lines and bigger injectors in planning stages... . See My Truck, Dads truck: 98. 5 3500 SLT QC LWB 4x4, Brother Truck: 92 W250 SLT CC LWB 4x4 (Dads old truck) Winter fun - 2000 Skidoo Summit 700
hvac We know you are reading this
he he he he he he
h2 ... ... ... ... ... ... .
END THE OPPRESSION FREE HVAC NOW
I am in no way an expert but twins is the only way to go to get enough air to run efficiently a bigger turbo sacrifices too much loww end but the dual stage setup gives you that all important bottom end and the top end we want with NO DRUGS only #2 and air baby checkout the pull tractor in the new TDR issue that is ours and it is all fuel and air BABY #ad
2001. 5 ETH/DEE DD3's EZ HX40 machined out for more flow, Custom 4" exhaust turbo back staight pipe with 5" chrome tip in front of rear tires,spa's, mcleod clutch, fuel lines,mag hytech rear end cover,psycotty air system,x heated,power mirrors,more to come
[This message has been edited by wiz1 (edited 02-18-2001). ]
The HX-40 is the cheapest and easiest way to add hp. Even though alot of people are pushing it past it,s designed limits,it,s still the best all around single turbo set up. The H2E is a nice choice for people that have enough fuel to drive it. It realy helps hp on the top end. Like Wiz said,2 turbos are better. My truck has scary low end power. It spools up faster than a HX-35 and can way out flow a H2E. I,m still test out the limits of my system but so far there is no draw backs. I need to get a new clutch in my truck to fully test the upper limits of this system. So far the max boost is 58psi sustained why,ll the clutch is slipping. I,ve seen as high as 62psi for a second before the clutch starts to slip and boost will fall to 55psi why,ll the clutch is slipping. I think that twins are the best way to go for any hp truck. It would make the ultimate towing set up. Instant boost to get a trailer going with enough air to keep EGT,s under control. The biggest problem is the cost. It,s not cheap to build a twin kit.
John/SP
hey sportbike email me I would like to talk to you further about this setup I like the pictures I don't see how that k&n will hold up though
Thanks for the advice Wiz. Thats the filter that I was using on my H2E set up. I already figured out that the filter isn,t strong enough. The right side has been collapsing under full load.
John/SP
Andy,I already tried one on my ISB. It,s a big hp set up for someone that is not willing to invest the money for twins. I used a HX-55W with a 19cm exh housing. I have a ported ATS manifold with adaptor. It also comes with a 5" down pipe. Wastegate is set for 60psi.
John/SP
Sportbike...
I think we need to change your handle to
"The Turbo Daddy"
Geeeez!
That ISB of yours has seen more huffers than Heffner and Wild Bill combined!
I'm with you on the HX40 and Majestic. Seems like more than adequate overkill for the street w/o having to start worrying about lowering compression with thicker headgaskets or piston changes.
Max
SteveAZ
My cruise control works the same as it did when the truck was stock. Absolutely no difference.
Bill R
94 2500 SLT 4x4 5 Speed, 3. 54 LS, JRE 4" exhaust, Autometer Pyro, Boost & Water temp gauges, Bosch 215 HP injectors, Timing @ 14. 7º, JRE Stage III #4 plate 270/675, AFC spring kit, Scotty Air, Bully Dog Propane Injection, Roadmaster Active Suspension, Optima Red Tops, Geno's Exhaust Blanket, Espar Heater (won it!), Synthetic lubes throughout.
How does the housing have so much effect on how the turbo performs? I can hit 1000 easy, without my EZ. After I add injectors to my EZ would a larger housing cool it off?
·1999 2500 QC LB Auto 3. 55 4x4
·Armorthane Bed liner, A-pillar gauges, RE-0880, EZ, Husky mats, strait pipe
[This message has been edited by JKloppe (edited 02-20-2001). ]
