Hi. I've recently been recommended this product by the folks at Mag-Hytec. It's supposed to be really good gear lube for the Dana 80 axle. So I just replaced the OEM lube that was in there.I had bought before at the dealer before, using my VIN. This new lube is almost purple in color, SAE 110, API GL-5 (MIL-L-2105E and AGMA 9005-EO2 specs).
Does anyone else here run this in the differentials? What's your opinion on it?
The reason I went for it was, that it was time to change the diff. lube, and was not able to find the recommended 75 W 140 lube. All local stores only had 1 or 2 quarts of the Royal Purple 75 W 140, and all the Valvoline on the shelves was gone, maybe sold out because was way cheaper.
So I decided to try this, after calling Mag-Hytec. I met David in their location, and he was really nice. He said this LE 1605 replaces the LE 607. I also bought and poured 2 bottles of the friction modifier.
Anyway, now is done, nothing unusual. I just want to see if any of you have experience with this lube.
Thank you.
Ilian
Thank you.
Ilian
