anyone using one of these filters?
Time for tricked out rear suspension...
TransferFlow owners
im sure they wont recomend or deny the need for additional filtration. but with the high pressure common rail system i have been hearing rumors that even the smallest particles are causing damage to the fuel system due to the high pressure.
You might get a fairly good handle on the GPM required by the engine then size the filter accordingly.
I use a RACOR 690T (90 GPM, 10um), OEM is 45 GPM, 10um I think. I just 2x the OEM to be SURE I was not creating a restriction. RACOR because that is what they do best of any of the commercial companies - filter (my opinion obviously, flame wars not needed).
Bob Weis
the 690 series has a 90 GPH rating as apposed to the the other which is rated at 25gpm or 1500gph... . yes i know seems like alot...
