I just replaced all 8 u-joints on my 2005 with 48RE trans. I used all Precision joints, here is what I found out, the #264 joint is for the front axle's, they fit perfect, on the front driveshaft the one at the differental end is a #235, the factory original does not have clips, it's installed with a glue substance, the #235 uses clips inside the yoke, they fit, but you have to grind down the clips a little, the 2 joints at the Cardan are #270, installing these are a real PITA, you have to work both of them a little together, because of the ball connection in the Cardan, with the #270 the clips are to thick, to make them work they have to be ground paper thin, or use epoxy on the ends to lock them in, the clips are on the outside of the yoke, I used epoxy, I will never have to replace them again, and if I did it still could be taken apart, then the rear driveshaft, with the 48RE long bed I used #330's, all 3 locations, this is a big heavy driveshaft, the #330's fit fine, but about half of th clips have to be ground flatted to have them fit. If you press, or pound them in, you can get the clips on, but the joint will be to tight, and grease won't be able to pass the end caps, I greased mine on the bench to make sure all 4 corners received grease. In my opinion the Precision joints are all, except the 264's a close fit, it would be nice if they made one that was an exact fit.
