This is the code I had when my lift pump quit... . sorrybagd99dak said:anyone that has ever gotten code p0148 (common rail high pressure). what conditions has it happend, what was the cause and the fix for the problem, i have gotten it a couple times when towing 5k behind me. truck is stock.
qzilla said:I have seen it caused by a dirty fuel filter as well as a lower than expected amount of fuel to the CP3. I have known people that have fixed with a fuel filter or a lift pump. I also know of one truck that got his injectors replaced and it fixed it.
Some trucks get the 0148 all the time and others cannot get it? It is a very general code and if it is not found with other fuel related codes it can be hard to diagnose.
Most people that get it either get it cruising at a constant speed or at WOT. Usually it does not get set with in town driving or if you accelerate and decelerate a lot on the highway.
Let us know what you come up with.
