Anyone with a Dynatrac kit installed?
REAR driveshaft u-joints shot again!!!!! which aftermarket is the best?
ARB Bumper
Kirwin
What are your thoughts? Is it really better? How did you fix the front wheel covers not having holes in them? Pictures? I'm thinking about doing this to my 03 3500. Looking for anyone's input. Ken Irwin
The kit doesn't work for a dually. Someone posted about trying ford adapters, but I haven't heard the outcome. Would like to do this myself if it will work on a dually.
We tryed to put the kit on my dually at dynatrac but the new hubs wouldnt fit thru are dually adapter for the front wheels. . Dynatrac machined a stock dually adapter out so the new hub would fit thru but there wanst enough material left to be safe and still strong enough. . I think they are still working on a fix. .
Dually conversion has been DONE... jkgdiesel at PavementSucks.com did this to his 3500. He bought adapters from somewhere (in the thread) that worked fine.
http://pavementsucks.com/forums/viewtopic.php?topic=85186
That thread was started by me... dynatrac is a PITA to deal with... PERIOD... I will not recommend them to anyone.
Other than the lack of customer service and price tag, it isn't a bad kit... basically a bolt on affair... most of the "put together pieces" come already assembled.
The center cap won't clear nicely on the 3rd gen since they started using extremely long wheel studs... one guy has modified his cap to make them fit... I'm going to try his trick.
If you go to the end of that thread, you will see there is ANOTHER company offering the kit, but has since sold that to offroad unlimited... guys are checking on it right now... so watch that thread.
steved
Im interested in this for a 03 Dually. The guy above had a 2nd gen dually with I guess 16" wheels. The adaptor he used is part # AA4. From what I can tell it works for wheels with a 4 7/8" center bore and uses 5/8" studs at the wheel & 9/16" at the hub. Our 17" wheels are 4 3/4" right ? So our wheels won't directly bolt up. Could our wheels be modified by having the center hole machined - ain't guys doing this with H2 wheels ? Any ideas or suggestions ?
