Long post
About two weeks ago I could smell antifreeze after I came in from a run late one night. The next morning the radiator was low and the overflow tank was completely full and I could see it had run over. I thought radiator cap, replaced it and took care of the coolant levels. The coolant gradually got lower in the radiator and the tank got fuller. All this is while the temp is completely normal for the loads I was pulling. The temp finally got up close to the 240 mark, I shut down for a while to let it cool off , then started it up and put water in and came on home with no problems. I took it to the shop last Thursday knowing what it probably was, but not believing that it could be the head gasket, and it tested positive for hydrocarbons in the coolant. Had to be the head gasket or possibly the EGR cooler. Pulled it down, the EGR cooler tested OK, looking at the head gasket, you couldn't see any "blow out" as such or feel anything. On the head you could see two places that were scorched outside the firing chamber. The head has been checked, it is flat, no warping, and has been magnafluxed (sp) and it has no cracks.
This should not have happened in my opinion. The truck is completely stock, and until this happened never got hotter than 210-215 max. It has been maintained correctly. It has been worked from day one, 90% of its 131,500+ miles have been towing a trailer, but this shouldn't have happened. I hope it is just a fluke. All the parts got in and the head got back today and it is going back together this afternoon. Should have it running and back to work tomorrow afternoon. It has been a long week wondering what was going to be found. I didn't post before now because I really wouldn't be able to answer any questions until I knew what happened. My other trucks went 419K and 345K miles without any engine problems. Like I said, in my opinion this shouldn't have happened. I hope it is a fluke, because it is an expensive fix. Give me a week after I get it back and I'll know if it is fixed.
