Off Roading Approach Angle, Cummins H1
Competition Block Filling?
Competition h2c turbo ?s
Having too much time on my hands, I decided to incorporate a vertical radiator stack on my '93/2003 Cummins H1. It's a '93 truck with a HPCR motor, transmission, and tcase from a 2003 Ram.
The vertical stack allows me to mount my front winch between the frame rails, behind the front tires of the truck. If I remove the brushguard, I should be able to climb a near 90 degree wall. Like I said, too much time on my hands. Tires are beadlocked 42's, stock size is 37". Custom radiator was about $500. Upper hose temp (as measured with an IR gun) was around 155 degrees, lower hose about 107 degrees. I got similiar measurements on the radiator face itself, so while I'll finish out a fan shroud, it seems to cool fine.
BTW, when cutting the Ram to bits to get to the drivetrain, I was so impressed with the build quality, I bought a 2006 Ram. Great truck.
Wow, thats a sweet ride!! The ultimate Hummer!! Thats exactly what I would have, a Hummer with a CR Cummins (except either fou door hardtop or softtop)
I WANT I WANT I WANT I WANT did i mention I WANT i didnt know you could get a 2dr open back hummer it looks like a beefy bad *** off road truck. damn where do i find one of those.
on a more serious note i would hate to adjust the valves in that truck. might be easier to pull the motor out everytime you want to lol.
Andres,
That's a very cool truck. I had a friend with a 6. 5l GM diesel H1 and it was sluggish! I'm sure the Cummins moves that one around nicely.
Nice work.
Jason
