Engine/Transmission (1998.5 - 2002) APPS Alignment
Is there any trick to getting the APPS aligned properly on the mounting bracket? Or just get the replacement as close to the same position as the original? I know I will need to disconnect the batteries, key on, and do the slow pedal push to floor trick to retrain the ECM/PCM. Anything else to consider when putting it back together? This seems too easy for some reason.
-Deon
