Sorry to be posting so much, but I bought this '02 and had a dead pedal incident. I pulled over and did the code trick with the key and got a P0121 code, which from the handy dandy list posted here, I found: Signal Voltage Too Low
APPS voltage input below the minimum acceptable
voltage.
Looks like someone cut and reran the APPS ground, ran a new blue wire to the ECM, then ran a new wire from the ECM to the computer(?) on the firewall behind the air cleaner, with an inline RF filter. I've read where the APPS can have a problem with RF noise. Even still, I got the dead pedal and the P0121 code.
Took off the throttle cable cover and found this:
voltage.
