Archived APPS help
Archived Need help in Calhoun, Ga
Archived Rockport, Corpus Christi, need shop
I just got home with my new APPS and the bracket is missing a hole for the kickdown cable I believe. Is the auto and manual the same electronics with just a different bracket. I can cut a hole in new bracket to accept cable or I could take the "factory calibrated electronics" off and the new bracket and put onto the old bracket. I really dont want to mess with the electronics if I dont have to. Thanks for your help in advance.
Sorry I can't be of much help other than to say I wouldn't cut anything without making sure it's the right part. Is it new, did you get it from dealer, if so - did they use your VIN to make sure you got the right one? Sorry to answer your question with a question.
If you got it at a dealer, or not, I'd call wherever it was and ask them how it's supposed to work if theres no hole for the kick down?
Joe, thanks for the reply. I have decided that if they are going to charge that much money for it that it has to be right. I do believe that the only difference is the bracket and not the switch itself after doing some more research on it. I cant believe that they just wont sell the switch seperate instead of having to buy the whole bell crank assembly.
What is APPS? All of these acronyms give me a pain.
Chuck
______________________________________________
2006 3500 QC SRW 4x4 48re Laramie Inferno Red
APPS is one of the technical references for the electric throttle position sensor on the newer electronic controlled engines.
There is a difference between auto and manual brackets.
Just take your APPS off the bracket and mount it to your existing bracket. . I did that on my 01' and didn't have any problems. . Just make sure the sensor is mounted on the bracket in the SAME EXACT PLACE that the old one was.
Oh yea-- for the guy that doesn't know what it stands for=
Accelerator
Pedal
Position
Sensor
My new one will be here tomorrow and I also ordered a new IAT and MAP sensors while I was at it. The kicker is that the auto one was $ 30 dollars more.
