Gentlemen:
I have a 1998.5 2500 4x4 with a NV4500 5-speed manual. Truck is pretty much stock except for a DDRP and a three gauge setup on the a-pillar. The symptoms are this:
When I am driving at speed (60-70 mph) without using the cruise control, I will experience a subtle drop-off in RPM's that will require me to adjust my foot-pressure ever so slightly. It is not a huge change in RPM or speed, maybe 5 mph at most, but it is noticeable. When I place the engine on cruise control, it does a better job in chasing the drop-off in RPM's but it is still present.
Other indicators are normal. Fuel pressure remains constant, ammeter needle is steady, engine temp is rock steady. No error codes. I spoke with the Dodge dealer locally,decent local operation, and they said it may be the APPS. I replaced the APPS unit three years ago (September 2012). The fuel filter is new.
I am open to suggestions as to troubleshooting as well as hoping to learn if anyone has encountered a similar problem.
Thank you in advance.
Mark Young
Fair Oaks, CA
Mark Young
Fair Oaks, CA
