My APPS Sensor (formerly know as the TPS to the undervalved) has been acting up lately. I'll be driving along just fine and the engine will drop to idle and the "Check Engine" light will come on. If I let off the go pedal and push down again, the truck will run normally again (except for the good old check engine light). The fault code is P0121 - "TPS A Circuit Range/Perf"
This had been happening fairly infrequently, but seems to be getting more frequent... 3 times on the way home yesterday.
I now hold in my hand the Bell Crank assmebly with the APPS Sensor attached to it. According to the service manual...
"The APPS is serviced (replaced) as one assembly including the lever, brackets and sensor. The APPS is calibrated to its mounting bracket. The APPS assembly is located at the left-front of engine belowplastic cable/lever/linkage cover (Fig. 20)
CAUTION: Do not attempt to remove sensor from its mounting bracket as electronic calibration will be destroyed (sensor-to-bracket mounting screws are permanentyl attached).
A new APPS Sensor replaces the whole bell crank assembly/mounting bracket and lever. This assembly for a 98. 5 24 valve automatic costs about $410 from your local stealer.
The parts guy from AutoZone shows a replacement Wells TPS (Part # TPS332) for $127. I would assume that is just the electronic portion of the APPS assembly I'm holding and you would need to remove the old sensor and re-mount the new one... potentially messing up the electronic calibration.
The electronic portion of the sensor is labeled ...
56028184
7323 RE 0. 617 VDC
USA
It doesn't appear that if you took the sensor off that there would be any way to disassemble and clean it... it's a sealed little electronic box.
Thoughts anyone ? How sensative is this electronic calibration if I were to ignore the warning and try to replace or repair just the electronic portion of the sensor ?
56028184
7323 RE 0. 617 VDC
USA
