Are aftermarket 3:55 gears available? If so, where?
Straight piped 3rd gen!!!!!
Zero oil pressure?
I've got the 3:73 gears in my 03' 3500 5 speed. I hate them. I had no idea there was that much difference from the 3:54 gears. My 01' 6 speed would run 118 mph. This truck will only run 99 mph. Is anyone offering a ring and pinion set for these new trucks?
WOW! I won't ask where you drive that you need a top speed of 118!:eek:
I don't think there are any other gear ratios currently available for either the AAM 10. 5" or 11. 5" rear end. I can only assume that if you wait long enough, there will be.
In the meantime, you could compensate by getting larger-diameter tires. It's interesting, the O/D ratios on the NV5600 and 4500 are very similar (0. 72 and 0. 75, respectively), yet I thought I heard maximum speed on the 6-speeds was 109 at the redline.
Well, my 01 was 500+ hp. I'm just not used to the sluggishness of a stocker. I don't necesarily need a top speed of 118, but I like to know its there. I enjoyed just getting out on the interstate running it as hard as it would go. And heres something else, I just got my 01 stripped down and its completely stock. It has a good bit more power than the 03. I can't verify the difference on the dyno, but the stock 01 with 15k #'s climbed the same hill 4 seconds faster than the 03. Its a 6% grade and the 01 would gain speed the entire pull, the 03 would barely maintain its speed at 80 mph. I just hope the chip, injectors and turbo help a great deal or I may be selling it and keeping my 01.
I plan to go to taller tires to raise my final ratios. Currently there are no gear sets on the market.
-Scott
Yeah my bone stock '01 would do 118 mph too, my '03 maxes at only 108. . . speed limiter (not governor) kicks in.
I talked to American Axle about 6 months ago and they said to expect more ratios to come available, but nothing right now :(
Vaughn
