Diesel/Otto Cycle Comparison
If using an engineering text comparison between the Otto and Diesel cycles, one must be careful. The Diesel cycle is similar to the Carnot ideal heat engine cycle in that the pressure in the cylinder never exceeds the compression pressure achieved before combustion starts. Fuel is injected to maintain that constant pressure until injection of fuel stops. Modern "Diesel" engines do not run on that cycle. Our modern "Diesel" engines run on what some term a dual cycle, as once injection starts, fuel is admitted at such a rate that causes cylinder pressure to exceed the level achieved by compression alone, just as in the Otto cycle. Near its peak during combustion, the cylinder pressure can flat top, and become constant as in the Diesel cycle thus the "Dual Cycle" moniker. True Diesel engines running on the cycle of the same name are eerily quiet due to the lack of violent change in cylinder pressure that cause mechanically transmitted knocks and bangs to shake the air around the engine and make the noises we are used to hearing. Even though his cycle was a dead end and runs today in a small number of engines in museums, his name lives on into history! The guys and companys that really made the oil engine what it is today are utterly forgotten, like Akroyd and the de la Vergne company... Also, our oil engines expand the hot gas further, extracting more energy from them than an Otto cycle engine. Since mixture ratio control is not required in a compression ignition engine, most oil engines do not have throttle plates that create large pumping losses on the intake stroke. With a vacuum in the intake manifold at part load, a spark ignited gas engine needs more power to pull the piston down against the difference between manifold pressure and atmospheric pressure on the crankcase side of the piston. Finally, an exhaust driven turbo-supercharger helps to recover some of the energy in the hot gas before it is lost out the tail pipe and uses that to cram more air into the engine and help push the piston the right way during intake. The last three effects help "Diesel" engines gain some efficiency advantages over spark ignited, non turbo-supercharged Otto cycle engines. Sorry for the long post, and the situation is more complicated than I have made it sound, but these are some of the basics.
