CumminsAholic said:O rings should hold. You're going to need a LOT bigger injector to get to 70 lbs though.
Corey
CumminsAholic said:I think your vp will die a very quick death if you stack a powermax comp on top of a edge comp on top of a smarty. I don't think they can handle a duty cycle like that. You'll need some spray, water, injectors or a combination of them to get where you want to go.
Corey
Jim Fulmer said:O rings should be good to about 60 - 70 lbs. You'll get different opinions from different people My opinion
I've been and have run a single O-Ring in the head now since the winter of 03'. During that time I have run anywere between 65 and 85 psi, timing at 24+ with Water/Meth (Meth adds timing) and have NEVER had a head gasket issue.
It really comes down to your head being very flat, a good O-Ring job and good maintenance on re-torques, especially in the beginning.
