I'm beyond ******. On Friday I dropped off my truck at the highly rated mechanic who's right next to my business. Pressed for time with Christmas related crap, shopping and preparation.... I did not have the time to do my ball joints so I figured I have them do it. I just did new tires so I needed an alignment.... But with a bad drivers side lower ball joint it's not going to align right. So I drop off the truck with the $800 box of Carli ball joint and a set of front pads. I told them to follow the ball joint directions to the T and to turn my front rotors and install the pads. Picked the truck up at the end of the day.... Another $800..... $450 in labor and $350 for a passenger side wheel bearing assembly. Upon driving home I keep getting a loud popping sound from both left and right ball joints.... The same sound the bad one was making! The next morning I get under the truck and take a look. The problem is..... They skipped the part of the directions that clearly say to check for clearance on the lower ball joint to make sure it does not contact the steering knuckle on full left/right turns. Both lowers rub on the knuckles because they did not grind the excess material off as stated in the directions.
But this is what go me madder than mad can get.......
All 4 bolts which are supposed to be torqued to 150ftlbs that hold the wheel bearing / hub assembly to the knuckle were all backed out 1/16" to 1/4". It's like they started them by hand but didn't follow through with tightening them. I jacked up the truck and tightened down 2 opposing bolts.... I could feel the bolt shoulder make contact with the backside of the flange and then as I tightened them down I could feel it pulling the bearing back into the axle. I left the other 2 bolts as they were so they could see where they F'd up. So now I am wondering if my wheel bearing / hub assembly is screwed since the entire bearing was hanging out 1/4" from being seated. That's a lot of weight on that bearing and race, Not being bolted in all the way... Slightly hanging out. I'm pretty sure I heard a noisy bearing when I was driving it... At first I thought it was tire noise but now I think the bearing is toast.
I called and got a hold of the shop owner.. Now it's back to the shop on Monday morning. I am going to make them pull it all apart, grind the knuckles and most likely replace that bearing assembly.... on their dime.
What really burns me is thinking about what could have gone wrong if I did not notice the hub bolts. Myself, Wife, Daughter and both dogs are going on vacation the day after Christmas... a 300 mile drive to our cabin in the Sierra's. I could just imagine the bolt working themselves out, letting the entire bearing move outwards.... Pushing the rotor outwards to drag against the new pads. I could guess a new rotor, pads and bearing at the minimum would be involved. Luckily the caliper would keep the axle from completely sliding out :--).
With being beyond pressed for time and still mountains of crap to do before Christmas.... I have to deal with this. Let's not forget I still need to get the alignment done at another shop..... on Monday as well!!!
Most mechanics I see these days are not mechanics but someone who can take something apart and put it back together. If your not under the car with them you better give it a good once over cause something may not be right.
