Are there any brake upgrades for an 89 one-ton?
Gear Housing & Cover
Intercooler Composition?
In perfect condition they perform ell unloaded; that's about ALL I CAN SAY POSITIVE ABOUT THEM.
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N air filter, cleaned-up exhaust, Dynomax straight-thru, rebuilt pump, thermostatically controlled twin 14" Permacool electric fans, intercooler), modified 518 OD transmission, Gear vendors OD controler, R-134 refrigernt, louvered front fenders, 93 aftermarket smoothie grille, new Dupont Chromacolor black, black-and-red rubber rubstrip, black headlights, powdercoated bumpers; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. To see my truck, Click on: <A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
Jesus" TARGET=_blank>http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
Jesus</A> saves!
See my post under--REAR WHEEL CYLINDER UPGRADE--a few lines back in this section. If you have any specific questions let me know.
Sam
Saw this ad in Trailerlife about severe service brake upgrade packages. Dont know anything about this company but may be worth a call- EGR at 1-800-468-2279
2001 HO 6spd,Quad cab,LWB,4x4,Flame Red,all options except for leather,Westin Brushguard/Push bar,Painless wiring,Radio Shack CB,my own design CB mount,Smittybuilt nerf bars,NW Custom rocker covers,Custom built stainless rocker light bars,DeeZee bedrails,Isspro pyro and boost gauges(more to come)
I had an '89 1 ton with single rears and 5 speed. Sold it at 170,000 to buy my 96.
Had the original shoes on the rear adn second set of pads on the front.
Try seeing if you can get Performance Friction pads for the front.
I thought the brakes on the 89 were better than my 96 3500. Already on my 3rd set of pads on the 96 at 118K and these are worn out. The OE pads caused the rotors to heat crack. The dually front hubs do not have replaceable rotors on a 2 wd so you have to purchase the entire hub and rotor combo at about $200 each! Also replaced the front calipers at 75K as the right front was dragging.
What specific problems are you having?
Redram
