Are there better brake calipers to fit a 2003 SRW 4X4 3500 that dont use plastic
Opinion please Lift pump
2008 Ram 4500 new front brake rotors needed: OEM or other brand??
JPM
Are there better rear brake calipers available to fit a 2003 SRW 4X4 3500 on the stock discs that don't use plastic pistons? I got a slight squeak that only shows up , slow speed ,when the brake is not applied, it goes away when the brakes are applied. Sometimes its barely notable other times it gets annoying , ( when everything is real hot , I think) The shop says I need new calipers, because one has its pistons not retracting enough.
Stick with it, the what you call platic is far better then the old metallic pistons. Because no rusting.
Complete Calipers cost around 70$ at Rockauto so it's a no brainer.
