If you read the handholding post I put up you will see that I'm in a snit about my fuel pressure dropping below 5 psi under full throttle and high rpm. I have only now discovered the problem as I just installed the BD low fuel pressure LED. Here is my question. The truck runs just like it has for the past 52000 miles since new. If the fuel pressure is only dropping below 5 psi under full throttle and high rpm which is a condition my truck rarely is at, that means that 99% of the time my fuel pressure is at or above 5 psi. Should I still be worried or just watch to see if i get the warning more often under less demanding situations?
