I am going to put BD twin turbos on my truck and plan on keeping the OEM head gasket with APR head studs.
I am going to replace them one at a time and torque each one up to the stock torque then take them up five pounds at at time in sequence to 122 ft/lbs.
My question is about the re-torque, why should I un-torque each bolt then re-torque it to 122 ft/lbs? That is what it appears everyone is doing but I do not understand why. What do I gain? It would seem if I un-torqued the bolt to re-torque it I am adding another flexing un-flexing of the head gasket. I can see why I would want to check and re-torque if necessary but can't understand the un-torquing of the stud.
What do you gain if you un-torque and then re-torque instead of just re-torquing?
I will be keeping my boost under 50 PSI.
