Two questions:
1) Is the bolt hole in the block open to the engine internals? Meaning, if you use a tap to extend the threads, could the shavings end up in the engine oil? I assume since you have to use a bottoming tap, it means the hole has a bottom and the shavings can't go anywhere? If so, I don't have a problem using a shop vac and small tube to clean out the shavings, however if I am going to risk getting shaving in the engine oil I would be very leary of doing this.
2) I plan to install the studs without removing the head and leaving the stock gasket in place. When should I retorque the head studs or is it even necessary since I'm not using O-rings?
Any tips or procedures for installing the studs?
Thanks for you help.
