Can someone give me correct procedure for torque.
I've read conflicting posts as to using oil verses moly lube on studs.
From what I read, I'm gonna bottom tap and vacuum block, bottom stud out, then back off 1/2 turn,(w/o lube). It's the torque and sequence I'm un sure of. Do I go once at 90, then 110 line torque, then 120 line torque & loosen each, one at a time before next torque? (w/moly)
Head is off for blown hg, and studs came today. I gotta get this thing going asap. Thanks, Bill
