Been reading several forums and haven't really found right answers. I have a 2000 with stock head gasket. Wanting to go up in boost. Whats best option here? arp studs with stock gasket good for how much boost? arp studs with mls gasket good to?(does this gasket work on a 2000 without compression changing)? Rather not o ring if I can get away with it!
I have Killer B (64 comp. 12 cm ex. housing wastegated at 40)still gets 1500+on egts. I have the sledpuller 66 coming this week. will i make more hp with more air then more boost?Or can I make same hp with more air and not the higher boost? When is enough boost enough?
