ASA intake questions
Not Quite Tuned
How hard is it to remove complete dash??
Does anyone know what BHAF air filter will fit on the ASA intake system ? Also, where can i get a pre-filter sock to go around it? What part #s?
Thanks Bill. I'll check it out. I am currently running the afe and pre-filter. Will the bhaf flow as well. I just don,t like a filter i have to clean and oil. I never know if i,m putting too much oil on or not enough.
I don't know on the flow difference. My only problem has been keeping the BHAF attached to my ASA intake. I didn't use Sam's support bracket that screws to the fender liner and holds the filter/intake up. I just layed it on the fender liner. Which might account for why it kept falling/vibrating off. Didn't matter how tight the clamp was either. Tried some black tape around the intake to make the o. d. a little bigger, to no avail. . Ended up running a screw through the small hole in the intake pipe and through the filter neck to secure the sucker from falling off. No oil samples to verify if the screw is allowing dirt in though. But the dang filter isn't coming off. 60 miles of no filter sure does allow dirt in.
