AST manifold - To coat fit areas or not
Speedometer correction
Test
What is the concensus on coating the fit areas.
Coat one side, both sides or no sides?
Will they fot together coated?
Has anyone coated the bolt heads?
With the 2000 series, they only coat the outside of it... when I got my back from Jet-Hot, it had tape on the outer sockets and some was on the inters. so I buffed it out with a drill and emery paper... my bolts are not coated... . I am consitering 316 stainless bolts in future..... JB
99 Black/Agate, Quad,Long bed,4x4, SLT,Auto,HX-40 16cm2 & ATS Exhaust manifold treated to Jet-Hot 2000(Gray),DD stage 3 injectors,4 wire Blue Box,"True" 5 inch Jet-Hot Coated exhaust from turbo to Tailpipe(Over the Axle),Borla Shoot-out Muffler,Suncoast converter, BD valve body and pressure-loc,Mag-Hytec trans pan,Amsoil ATF-4,Mobil Super Delvac 1300,fuel line up-grade from lift pump to filter and from filter to injection pump,Auto meter Ultra lite gauges:Boost,EGT,Fuel Pressure,Trans Temp, Valentine 1, EZ-pass
